How to add a content file link to the table of contents hierarchy
Use the following procedure to add a content file link to the table of contents hierarchy for the Information Console help system.
1 If you are linking to an anchor, navigate to the document root directory. Open the content file that contains the anchor to which the table of contents will link. Determine the value of the name attribute for the anchor. Then, close the content file without saving it.
3 In a text editor, open the files.js file and determine the internal file array number for the content file, either that you opened in step 1 or that you are linking to directly. Close files.js without saving it.var B=A.fN("About business reporting using Actuate products","1#147349");
n var is a keyword that must precede the entry if B has not been defined as a variable in this file prior to this line. Do not use var if B has already been defined.
n ''About business reporting using Actuate Products'' is the string to display in the table of contents for this entry.
n #147349 is a number sign (#) followed by the value of the name attribute for the anchor established in step 1, if it is applicable. Do not append any additional characters to the array number of the target file if you are just linking to the file and not to a marker.
