Changing measures and dimensions
Edit measures with Crosstab.editMeasure( ). In this example, the measureName measure named measureName takes on a new value:
Use Crosstab.changeMeasureDirection( ) to change the measure direction. Pivot the cross tab with Crosstab.pivot( ).
Use Crosstab.reorderDimension( ) to change the order or axis type of a dimension within a cross tab. This example moves the index of a dimension within a cross tab from 1 to 5. The dimension’s axis type changes from a row axis to a column axis:
The measure placement order can be altered using Crosstab.reorderMeasure( ). In this example, a measure’s index changes from position 1 in the cross tab to position 5:
Measures and dimensions can also be changed with the functions in the measure and dimension classes. In this example, a dimension axis changes from column to row:
if (currentAxis == actuate.xtabanalyzer.Dimension.COLUMN_AXIS_TYPE){
