Running file jobs : Running a file job : Running a BIRT Spreadsheet executable job
BIRT Spreadsheet executable files are available in Items You Can Run. They run as file jobs to create a new BIRT Spreadsheet documents. Developers create spreadsheet executable files in the BIRT Spreadsheet Designer software.
Users can run a spreadsheet executable job in the following ways:
n
Run: prompts for parameters if required, starts generating the document immediately. The resulting document is downloaded as a Microsoft Excel file.
n
n
Run and View: prompts for report format, prompts for parameters if required, and starts generating the document immediately. The resulting document downloads or opens in the selected report format.
n
Schedule: prompts for parameters if required, scheduling, and save-as details before entering the job in the job task list. Scheduling is described later in this section.
