Running file jobs : Using parameters : Using multiple-value parameters
Multiple-value parameters are drop-down lists, radio buttons, or check lists. The values you select in a multiple-value parameter restrict the resulting document data to the elements with the selected values for that parameter. For example, selecting years from a multiple-value parameter, causes the generated report to show data from the selected years.
