Using skins
Information Console provides graphic layout options called skins. A skin affects the appearance of the My Documents page navigation pane. A user can select a skin in the user options, described later in this document.
Most examples in this manual show and describe Information Console using the default Tree View Skin. Other skins are described later in this document. Information Console administrators can create new skins and edit existing ones.
