Managing folders and files : Finding a file : Filtering files and folders : How to filter files
How to filter files
1
Figure 2-41  Enabling filter options
2
3
4
Type the special character * as the last character. For example, the following shows files that start with the letters Cu:
Cu*
5
Figure 2-42  Filtering reports by viewable documents
Optionally choose a different folder to apply the same filter inside the new folder.
6
