How to run a spreadsheet executable
To generate an instant spreadsheet document without saving it in the Encyclopedia volume:
Figure 4-6 Selecting the categories view
2 Navigate to the spreadsheet executable file in Items You Can Run and select the file name to generate the latest version. The generated document appears unless the file job requires parameters.Figure 4-7 Selecting parametersSelect or type values for any required parameters. Optionally use the Query by Example syntax if the parameter is an ad hoc parameter, as explained later in this section.
